Trying to build thru xcode
Re: Trying to build thru xcode
Post by davilla » 06 Mar 2017, 16:43
Everbrave wrote:terminal frozen before finishing the make; repeating the whole process :(
make Xcode_depends in root or in user (where MrMc is placed)?
root as in root dir of MrMC. Never, ever build as user==root or use sudo. The build system is designed to not require that hammer.
Everbrave
Post by Everbrave » 06 Mar 2017, 19:36
Success :) running perfectly on my iPad Pro 9.7.
Will try packing now.
Everbrave
Post by Everbrave » 06 Mar 2017, 19:58
cd tools/darwin/packaging/ios
chmod +x ./mkdeb-ios.sh && ./mkdeb-ios.sh release
returns ...
Packaging Release target for iOS
MrMC.app not found! are you sure you built release target?
and then prompts to user in the terminal
what is missing?
Post by davilla » 06 Mar 2017, 20:14
Everbrave wrote:cd tools/darwin/packaging/ios
returns ...
what is missing?
Humm, something might be broken there, we always build for archive. That makes an ipa which we upload to the Apple Store.
For iOS, we call the App "MrMC Touch", which would be why 'MrMC.app not found',
Everbrave
Post by Everbrave » 06 Mar 2017, 20:28
I built while the iPad was connected because it refuses to build for a generic device; how can I build for an archive?
Post by davilla » 06 Mar 2017, 20:52
Xcode Menu -> Product -> Archive.
I'd solve the build for generic device 1st. We always build that way when doing an Archive.
Everbrave
Post by Everbrave » 06 Mar 2017, 21:13
yes, thanks ... discovered this option; completed successfully and now exporting the archive; takes a long time (rotating circle on compile bitcode) :)
Everbrave
Post by Everbrave » 06 Mar 2017, 22:02
MrMC.ipa successfully exported with the proper profile and installed on iPad :)
EDIT:
the next question would be, what can be saved in building updates in terms of steps, i.e., time?
Compiling the new code will be necessary, of course, but the libraries remain, probably, largely unchanged. Newly linking is also necessary.
So, how do you do you manage that?
Post by davilla » 07 Mar 2017, 01:46
1) Depends only needs rebuilding if something changes in there. In fact, we keep all three darwin platforms built and switch by changing the depends configure. The depends build system is designed to keep them separate.
2) make -C tools/depends/target/xbmc, make xcode_depends is only needed if 1) changed or you switch darwin platform.
Archive is only needed for deployment, for testing, we do builds/debug to the physical device. Those are fast once done the 1st time. In fact, changing platforms only take 5-10 mins if depends are already built.
Every now and then, I nuke it all and rebuild everything from scratch. This way we are sure we did not miss keeping something in sync.
For serious construction, we work under osx platform. It's the fastest way to get new core code up and running. Then we fixup (if needed) tvOS/iOS then droid as droid is done on a Linux based i7 box. The Linux box has it's own git checkouts (one for 32bit, one for 64bit) and these have smb mounts so I can edit with a real editor (Xcode). Then ssh in via terminal and command-line compile/package or adb install over net.
Everbrave
Post by Everbrave » 07 Mar 2017, 06:42
davilla wrote:1) Depends only needs rebuilding if something changes in there. In fact, we keep all three darwin platforms built and switch by changing the depends configure. The depends build system is designed to keep them separate.
Got it, thanks :)
But, why three Darwin platforms, tvOS, iOS and what's the third?
Users browsing this forum: No registered users and 11 guests
