Trying to build thru xcode
Hello,
I am a paying customer of mrmc but i also want to build a working version thru the github... i have gotten thru most of it with the exception of a few errors keeping me from completing the build...
Is there a build wiki for tvos? I have tried following the ios version but it has lead me to the errors i am currently having. Not even sure if this is the right place to bring this up.
Re: Trying to build thru xcode
build depends with
./configure --host=arm-apple-darwin --with-tarballs=/Users/Shared/tarballs --prefix=/Users/Shared/mrmc-depends --with-cpu=arm64 --with-platform=tvos
your prefix will be different or use the default
make -C tool/depends/target/xbmc
make xcode_depends
then build tvOS in xcode. we use xcode 2.8.1 right now.
EDIT: that's Xcode 8.2.1
make xcode_depends
Ok thanks a lot! Going to give a try...
Did you mean 8.2.1 for xcode?
yesSelest wrote:Ok thanks a lot! Going to give a try...
Well I am not sure what wrongs but Mrmc freezes immediately upon opening on the ATV4. It builds just fine in Xcode and then installs just fine but once it starts running it freezes right away and gives me and error that is in the pic below .
here are my procedures maybe someone can point out where i went wrong
cd $HOME
git clone git://github.com/mrmc/mrmc.git MrMC
cd $HOME/MrMC
cd tools/depends
./bootstrap
./configure --host=arm-apple-darwin --with-cpu=arm64 --with-platform=tvos
make
cd $HOME/MrMC
make -C tools/depends/target/xbmc
make -C tools/depends/target/binary-addons
make clean
make xcode_depends
I then start Xcode
I then change bundle identifiers in tvos and top shelf by adding my last name
I then add my provisioning profile to tvOS and top shelf areas
i then add added "group app" to my app id which then showed up under "App Groups" under Capabilities with check marks
I then run it to my apple tv and it gets all the way thru to the installation but when it starts running is either freezes or crashes right away.
Any help would be appreciated. Using Xcode 8.2.1.
cd $HOME
cd $HOME/MrMC
cd tools/depends
./bootstrap
make
cd $HOME/MrMC
make clean
make xcode_depends
I then start Xcode
what does "bt all" give you?
paste it on pastebin.com please
add this patch ( http://pastebin.com/kpuYjmmr )
The issue is topshelf uses group.tv.mrmc.shared and that is via our account. You would need to add your own group/topshelf IDs.
Don't mean this to be a stupid question but I am little new to using Xcode and terminal...... do i apply this patch thru terminal in a specific folder or can this be patched thru Xcode somewhere such as the debug console area?
Thanks for the help davilla
Edit: Since i didnt know how to patch i went into the file itself and modified its contents. I noticed the group identifiers were still under mrmc even though they were changed under capacities.....so i changed them to the ones i created yesterday and it seemed to have worked. Got a running install. Hope it right. Thanks a lot for the help.
Edit2
I removed my edit i wrote about above and basically started over and manually patched what you suggested by editing the file. Either way that i do it...they both install just fine, run well expect for one issue. The only problem I am having now is the skin that I use (PM3) is running at a very high cpu usage. 60-70%, ironically the other 3 skins run just fine at 8-11% on average. I haven't done anything to settings yet except just run this file on the atv. but this high cpu usage is causing intermitant freezing. Seems like i just can win on this.... any ideas?
here is the log, I have noticed the app store version on my other ATV's is shown cpu usage at about half that on the similar skins...
http://pastebin.com/NRLUxX7P
btw if this is still a top shelf problem is there a way to disable it then... i am not really keen about having my movies shown at the top anyway.
Users browsing this forum: Google [Bot] and 3 guests
