Trying to build thru xcode
Re: Trying to build thru xcode
Post by davilla » 27 Jun 2017, 21:56
do the same you did before
Everbrave
Post by Everbrave » 28 Jun 2017, 09:26
27 Jun 2017, 21:56
done, thanks !
trescatorce
Post by trescatorce » 01 Dec 2017, 13:51
Hi davilla! Excelent work
I'm trying to compile mrmc from git, but I'm stuck when make the program. I want to compile for Apple TV 4K, so I typed:
cd MrMC
cd tools/depends
./bootstrap
./configure --host=arm-apple-darwin --with-cpu=arm64 --with-platform=tvos
make
The error is when I try to do make:
ABBC3_OFFTOPIC
cd /Users/Shared/xbmc-depends/tarballs; /usr/bin/curl -Ls --create-dirs -f -O ftp://ftp.gnupg.org/gcrypt/libgcrypt/li ... .3.tar.bz2
make[2]: *** [/Users/Shared/xbmc-depends/tarballs/libgcrypt-1.7.3.tar.bz2] Error 56
make[1]: *** [libgcrypt] Error 2
make: *** [target/.installed-appletvos11.1_arm64-target] Error 2
I'm trying to compile ulxmlrpcpp but again I've a new error...so, can you help me?
I'm using macOS Sierra 10.13 under VM, XCode 9.
Thanks!
Post by davilla » 01 Dec 2017, 14:22
we use XCode 9.1 for release and XCode 9.2b2 for testing.
also check /Users/Shared/xbmc-depends/tarballs/libgcrypt-1.7.3.tar.bz2
make sure it downloaded right, it not rm it.
trescatorce
Post by trescatorce » 01 Dec 2017, 17:27
Yes, I manually download and now I don't have any error except:
ABBC3_OFFTOPIC
cd appletvos11.1_arm64-target; patch -p1 < ../0001-lavc-aarch64-simple_idct-fix-iOS-build-without-gas-p.patch
patching file libavcodec/aarch64/simple_idct_neon.S
Hunk #1 FAILED at 61.
Hunk #2 FAILED at 101.
Hunk #3 FAILED at 153.
Hunk #4 FAILED at 164.
Hunk #5 FAILED at 181.
Hunk #6 FAILED at 200.
Hunk #7 FAILED at 219.
Hunk #8 FAILED at 263.
Hunk #9 FAILED at 328.
9 out of 9 hunks FAILED -- saving rejects to file libavcodec/aarch64/simple_idct_neon.S.rej
make[2]: *** [appletvos11.1_arm64-target] Error 1
make[1]: *** [ffmpeg] Error 2
I think is the same error than: viewtopic.php?f=15&t=1026&start=30#p9140
I'll try to apply the same fix.
Thanks davilla ;)
Post by davilla » 01 Dec 2017, 18:43
yea, comment that line out in the ffmpeg makefile. not sure why it does this sometimes.
trescatorce
Post by trescatorce » 02 Dec 2017, 14:49
yes, now I can make it without problems, but now in XCode I can't compile MrMC:
ABBC3_OFFTOPIC
Code Signing Error: No account for team "8U6WVDN2Q6". Add a new account in the Accounts preference pane or verify that your accounts have valid credentials.
Code Signing Error: No profiles for 'tv.mrmc.mrmc.lite.ts' were found: Xcode couldn't find any tvOS App Development provisioning profiles matching 'tv.mrmc.mrmc.lite.ts'.
Code Signing Error: Code signing is required for product type 'TV App Extension' in SDK 'tvOS 11.1'
And yes, I've an Apple developer license.
Thanks again davilla.
Post by davilla » 02 Dec 2017, 14:54
You need to change the signing account to yours.
Why are you building for Lite ?
trescatorce
Post by trescatorce » 02 Dec 2017, 16:54
Yes, but where? I find across xcode and the only place is in General --> Signing, where I put my team and my iOS developer license. Also y putted it in Build Settings:
Release: iPhone developer license (my license code)
Code Signing Style: Automatic
Development Team: My team
Provisioning Profile: Automatic
It's there or I'm wrong?
PS: How I can build for normal version?
Thanks again davilla ;)
Post by davilla » 02 Dec 2017, 16:58
Build "MrMC-TVOS", not "MRMC-TVOS-Lite
these will appear after opening MrMC project, reset them
git checkout MrMC.xcodeproj/xcshareddata/xcschemes/MrMC-TVOS-Lite.xcscheme
git checkout MrMC.xcodeproj/xcshareddata/xcschemes/MrMC-iOS-Lite.xcscheme
