3D H.264 MKV playback in 2D (not asking for 3D support)
mukiex
Post by mukiex » 14 Aug 2018, 01:24
Platforms tested:
iPhone X
iPad Pro (A9 chip)
Issue:
When playing an MKV file with a 3D H.264/MVC video track, most media players will default to playing the 2D H.264 stream, especially if they do not support 3D MVC.
However, in MrMC, I get a failure to play regardless of which acceleration method is used:
- Under VideoToolbox (AVFoundation is disabled) : File opened, MrMC asks for a 3D playback method, and then never loads a new image. That is, it still shows the file menu. When the back button in the menu is pressed a few times, the playback begins to load in a very glitchy way (the playback bar starts flashing on-screen). Audio does not play.
- Under AVFoundation (VideoToolbox is disabled) : File opened, MrMC asks for a 3D playback method, and then displays a black screen. Audio plays in full. In addition, MrMC is able to generate a thumbnail of the file.
I can provide a sample MKV (10 seconds, 57MB) via PM if it's helpful.
Not sure if this is a known issue, and I'm mostly raising it because beyond that small flaw, MrMC is pretty much the gold (platinum?) standard for a media player in iOS for me.
UsefulG
Re: 3D H.264 MKV playback in 2D (not asking for 3D support)
Post by UsefulG » 14 Aug 2018, 05:56
Try disabling all acceleration and try it again. It worked for me on tvOS and iOS.
mukiex
Post by mukiex » 15 Oct 2018, 00:46
That seems like a really messy workaround given that you'd have to disable hardware acceleration across the board, or at least every time you wanna watch a movie that has a 3D MVC track. I do appreciate the suggestion tho.
Post by davilla » 15 Oct 2018, 11:38
debuglog with acceleration enabled.
Post by timstephens24 » 15 Oct 2018, 23:02
mukiex wrote:
15 Oct 2018, 00:46
It's the only way for it to work currently.
