Issues with simple iptv
jelvs_sousa
Post by jelvs_sousa » 06 Nov 2017, 11:55
Hey, finally found an app that does exactly what I want. But I'm having a problem with the PVR client on ios. I enable the PVR, and it says none is selected, so I select the simple iptv client I enter the remote address and I enable it. The problem it seems is that for a reason it doesn't start? Do you know what it seems to be? Thank u very much! 8-) I'm running the last ios version, have the problem with my iPad air 2, and my iPhone 7 plus
Re: Issues with simple iptv
Post by amet » 06 Nov 2017, 12:34
IPTV add-on works, I use it ... but you have to enter m3u8 list address and not the download link for the m3u8 :)
let us see the debuglog when it "fails" to connect please
jelvs_sousa
Post by jelvs_sousa » 06 Nov 2017, 17:49
Hi, thks for your reply im not currently at home, but i use it the same way at kodi, and other ios apps and never had a problem. but sure when i get home i post it. ;)
jelvs_sousa
Post by jelvs_sousa » 06 Nov 2017, 18:02
It seems i make it work. I guess the problem i had i was using the same link to fetch the channels and also the logos, and thats why it was not working. But i currently use it on kodi , and i can make it work
