Change Skip Time Increments
Please, only How to's in here. No questions or support, use appropriate subsection for that
sringgen
Post by sringgen » 25 Sep 2016, 18:35
I am wondering if anyone knows how to change the time for skips. What I want is 30 second skips forward and 10 second skips back. The 10 second skips forward are a waste of time. If I want to skip through a commercial I have to hit it 5 times for every minute. This add up to 15 times for an average 3 minute commercial.
I have found 30 seconds forward and 10 seconds back is ideal. Can I ssh in and make changes somewhere? I don't see the option anywhere in the settings.
TIA
Re: Change Skip Time Increments
Post by cosmoxl » 25 Sep 2016, 18:48
settings>video>playback>skip steps. but you have to be in settings level advanced or expert to see it.
sringgen
Post by sringgen » 25 Sep 2016, 19:19
I have already tried this and it doesn't work. Still 10 second skips. Maybe I should clarify that I am using an Apple TV 4. When I swipe to the right it is always 10 seconds no matter what I select in the skip steps menu.
Post by cosmoxl » 25 Sep 2016, 19:30
sringgen wrote:I have already tried this and it doesn't work. Still 10 second skips. Maybe I should clarify that I am using an Apple TV 4. When I swipe to the right it is always 10 seconds no matter what I select in the skip steps menu.
if you swipe twice, three times, four times quickly the interval increases. or if I'm using the siri remote I just tap the edges.
sringgen
Post by sringgen » 25 Sep 2016, 19:44
I am using the Siri remote. With the skip settings set to 30 seconds and -10 seconds, when I swipe twice it jumps ahead 1 minute. When I swipe once I get 10 seconds. This doesn't make sense to me because neither of these are 30 seconds. There doesn't appear to be any way to get 30 seconds using swipe twice or once.
Do you actually have an Apple TV 4 in front of you to test with? I also can tap on the right side and this brings up the menu on the bottom of the screen. All of my software is up to date. What settings are you using for the Siri remote?
If I have Match Apple tvOS selected and Disable swipe controls selected it is very difficult to accurately navigate the menus. I prefer to have Match Apple tvOS Standard turned off so that in the menu it only moves one item per swipe. (But I have tested with it on too)
sringgen
Post by sringgen » 25 Sep 2016, 19:47
I was just playing around with settings. If I set skip forward and back to 10 and -10 then I get 30 seconds forward and 30 seconds back. Still not what I want. I want 30 seconds forward and 10 seconds back.
Something is buggy with the settings because it is never what I have it set to. FYI, I have 4 Apple TV 4's and they all act this same way.
sringgen
Post by sringgen » 25 Sep 2016, 19:50
I think I figured it out. The skip settings are inverted. With -30 and 10 settings I get 30 second skip forward and 10 second skip backwards.
Post by amet » 25 Sep 2016, 19:53
this is what I have setup now, and one click right goes +30 sec and one click left goes -10sec
sjamp7
Post by sjamp7 » 30 Jul 2017, 15:47
I do not see the skip settings as shown below. Could you pls advice on how to get there and actually setup forward capabilities?
Thank you
Post by amet » 30 Jul 2017, 15:50
could you share with us what you so see please? this menu exists and nothing has changed in that regard
are you sure you are in "Expert" mode? bottom left of the menu
