MrMC on macOS Sierra
Please, only How to's in here. No questions or support, use appropriate subsection for that
Lawful
Post by Lawful » 19 Jan 2017, 16:43
Hello, thank you for accepting me. I'm new to this hobby. Is it any way to install MrMC in macOS Sierra? thank you. :)
Re: MrMC on macOS Sierra
Post by davilla » 19 Jan 2017, 16:58
Lawful wrote:Hello, thank you for accepting me. I'm new to this hobby. Is it any way to install MrMC in macOS Sierra? thank you. :)
MacOS is not officially supported. We do however use MrMC on OSX for development so it can be built and run under OSX. To get MrMC for OSX, you would have to self build it under Xcode.
Lawful
Post by Lawful » 19 Jan 2017, 19:02
Thank you so much for your help. Is there any tutorial to do it? is it safe to do it if I don't know Xcode? thanks again. :)
Post by davilla » 19 Jan 2017, 19:57
well, I would not recommend diving into coding if you have never done it. Lots of ways for epic fail :)
basically, checkout MrMC from github.
compile depends with ./configure --host=x86_64-apple-darwin --with-tarballs=/Users/Shared/tarballs --prefix=/Users/Shared/mrmc-depends
make xcode_depends, then build from xcode. There are two readme's docs/README.osx and tools/depends/README
Lawful
Post by Lawful » 20 Jan 2017, 00:13
Thank you Sr... I better stay out of trouble. :D
