Live TV suggestions
Live TV suggestions
Post by timstephens24 » 04 Oct 2018, 23:30
A few suggestions for issues I've been having trying to switch to use MrMC for watching live tv.
1. [[Found the fix for this, default "Timeout when starting playback" was 10 seconds so I changed it to 1]] Speed up the time to load the channel. Right now (even with the option of 'LiveTV playback wait time' set to 400ms) it takes about 8+ seconds to load up the channel from my HDHomeRun or from an IPTV stream when I initially start playing. If I switch the channel it's almost immediate most of the time, and it should be like that always.
2. [[Found the fix, thanks @garyd123]] When I click on a channel, don't give me a pop-up asking me to Close, Switch, Record, or Find similar. I just watch to play it (or switch) 99.5% of the time.
3. Scrolling with the Apple TV remote should be a lot faster. It takes forever to get through 100+ channels.
4. Wrap from top to bottom on the guide.
5. Disable tapping up/down to change the channel. Live TV remote controls are still stuck in the old way, and it should require a click to switch the channels or jump forward/back.
garyd123
Re: Live TV suggestions
Post by garyd123 » 05 Oct 2018, 01:40
I want to say there's an option to setup #2, but I'm not certain as I'm not in front of mrmc right now.
Certainly I want to echo #3 & #4. #4 would be less annoying though if #3 was able to be addressed.
The guide needs progressive scrolling as per the rest of Kodi eg movie lists. It is REALLY annoying trying to scroll through a large list of tv channels one at a time.
Post by timstephens24 » 05 Oct 2018, 15:29
garyd123 wrote:
05 Oct 2018, 01:40
Found it thanks.
Post by timstephens24 » 07 Oct 2018, 13:48
timstephens24 wrote:
04 Oct 2018, 23:30
I've got a workaround for this but only if you use a Harmony remote (or anything I guess with SkipForward/SkipBackward). I used the Keymap Editor Extension that was added in 3.7.0 to globally map the navigation page up/page down to SkipBackward/SkipForward. Now when I hit the 'Channel Up' button on the remote it will jump up by a page, and same with Channel Down. An added bonus is that it works globally, like in the Movies and TV Shows sections, too.
garyd123
Post by garyd123 » 08 Oct 2018, 23:03
Fwiw if you hold down on a firetv remote it scrolls quickly so I assume the same should be possible on Apple tv.
Post by timstephens24 » 09 Oct 2018, 00:16
There's no holding down with the Siri remote :lol:
Post by amet » 09 Oct 2018, 03:59
Not unless you get a silver one :)
garyd123
Post by garyd123 » 09 Oct 2018, 05:06
Whatever, it would be nice if it was fixed anyway.
Post by amet » 09 Oct 2018, 05:15
What exactly?
What skin are you on? Scrolling through list of channels on opacity is not slow on appletv, is it Ariana?
garyd123
Post by garyd123 » 09 Oct 2018, 07:34
Yes Ariana skin, see the thread I started in the Ariana part of the forum.
