Stop refresh/res changes except to match media
Quartermass
Post by Quartermass » 16 Sep 2018, 23:11
I have my Shield connected to an AVR and then to a TV.
That means if the Shield changes resolution/refresh rate the AVR then takes a few seconds to change, and following that the TV takes a few seconds.
These delays could be almost eliminated if MrMC was set to maintain the last resolution used until it had to make a chance to match media.
So if I'm watching a set of media at for example 4K/50hz then MrMC would stay at 4K/50hz, until I started watching something that wasn't, and it'd only switch then.
This would mean that MrMC always played the correct resolution/refresh rate to match the content playing, but cut down heavily on resolution switches.
Re: Stop refresh/res changes except to match media
Post by cosmoxl » 16 Sep 2018, 23:18
Sounds OK to me.
In the meantime, and if this isn't possible, you can disable refresh rate switching but manually set the desired refresh rate yourself in settings>system>video.
Post by koying » 17 Sep 2018, 18:45
That'd be fine at 50/60 fps, but you dont really want the GUI to run at 24 fps, do you?
Post by cosmoxl » 17 Sep 2018, 21:34
koying wrote:
17 Sep 2018, 18:45
It makes things feel really slow but I have to do it on my shield every time I want to watch netflix or amazon at the proper frame rate since they don't auto switch. :)
