Custom keys for Plex For Kodi.
SUPERBIF
Post by SUPERBIF » 14 May 2018, 10:00
Will you look at getting custom keys working when using PlexForKodi addon?
Thanks for the great work.
Re: Custom keys for Plex For Kodi.
Post by amet » 15 May 2018, 04:55
You can’t target only one addon with keymap modifications, it’s all or nothing.
Keymap editor is in TestFlight now and that can be used to adapt mapping to your liking.
Nothe: There is an issue with keymap addon it ATM that we are looking at
SUPERBIF
Post by SUPERBIF » 25 May 2018, 08:04
Thanks for the answer Amet.
What about the customsiriremote.xml I've used before, should I delete in and start over?
