Allow to downgrade resolution
Slice314
Post by Slice314 » 16 Feb 2018, 11:13
Shield has the possibility to change (automatically) resolution and refresh rate.
For example, when I play a 1080p file and my Shield it's setted to 4K, the SPMC fork change the resolution to native content (1080). With this, the TV receive the signal at 1080 and then upscale to 4K (it does a far better job than the Shield).
Could we get this feature as well? @koying already implemented it and it works wonders.
SUPERBIF
Re: Auto resolution switch depending on content (Nvidia Shield)
Post by SUPERBIF » 17 Feb 2018, 12:59
That would be wonderful feature. +1
Slice314
Post by Slice314 » 28 Feb 2018, 13:26
Could we merge @Koying code to "Allow to downgrade resolution" into MrMC?
https://github.com/xbmc/xbmc/pull/13191
This would improve MrMC enormously on the Shield... and the code is already there. @Davilla?
Slice314
Re: Allow to downgrade resolution
Post by Slice314 » 06 Mar 2018, 19:08
is this possible in a foreseeable future? :roll:
Can the Nvidia Shield get some love?
Post by davilla » 06 Mar 2018, 19:23
yes
Boulder
Post by Boulder » 07 Apr 2018, 15:26
Has this one been included in MrMC or is it still pending? I have a high end 4K TV which has a pretty good upscaler and my sources range between 480p and 4K. It would be a big plus to be able to throw the native resolution (or closest to it) to the TV and let it handle the upscaling.
Post by cosmoxl » 07 Apr 2018, 15:32
Boulder wrote:
07 Apr 2018, 15:26
I think it's coming in the next release. The testflight notes mention it but so far the testflight isn't posted.
Boulder
Post by Boulder » 07 Apr 2018, 15:47
cosmoxl wrote:
07 Apr 2018, 15:32
Boulder wrote:
07 Apr 2018, 15:26
Thanks a lot for the news! MrMC just keeps getting better and better :D
