Scheduled library update/cleanup
sirmcftv
Post by sirmcftv » 26 Jul 2017, 19:59
Any alternatives in MrMC for the Kodi addon XBMC Library Auto Update? I manage media files directly on a Linux server (NFS) where I add and also remove files. I can trigger a manual library update once in a while, trouble is that getting to the "Clean library" menu is a hassle. Ideally I'd like something that scans and cleans up the library every "n" hours.
Thank you for your help.
eazytv
Re: Scheduled library update/cleanup
Post by eazytv » 27 Jul 2017, 04:30
I would appreciate this as well.
Post by amet » 27 Jul 2017, 04:40
Moved to requests
sirmcftv
Post by sirmcftv » 27 Jul 2017, 04:42
Is it appropriate to file a Github issue or those are for bugs only? Thanks.
Post by timstephens24 » 27 Jul 2017, 10:57
You could do this from your Linux box with cron and a curl command.
curl --data-binary '{ "jsonrpc": "2.0", "method": "VideoLibrary.Scan", "id": "mybash"}' -H 'content-type: application/json;' http://192.168.1.100:80/jsonrpc
curl --data-binary '{ "jsonrpc": "2.0", "method": "VideoLibrary.Clean", "id": "mybash"}' -H 'content-type: application/json;' http://192.168.1.100:80/jsonrpc
Post by davilla » 27 Jul 2017, 12:59
sirmcftv wrote:
27 Jul 2017, 04:42
Github issues is fair game for bugs or feature requests.
sirmcftv
Post by sirmcftv » 27 Jul 2017, 14:56
timstephens24 wrote:
27 Jul 2017, 10:57
Interesting idea, but it assumes that MrMC is up and running, it allows remote requests, etc. There is an addon already that does this quite well, if it could be made part of MrMC ...
Post by davilla » 27 Jul 2017, 15:00
sirmcftv wrote:
27 Jul 2017, 14:56
27 Jul 2017, 10:57
If MrMC is not up and running, even an internal lib auto update would never fire.
sirmcftv
Post by sirmcftv » 27 Jul 2017, 15:39
27 Jul 2017, 15:00
sirmcftv wrote:
27 Jul 2017, 14:56
27 Jul 2017, 10:57
Correct. But there's an option to run a library update/cleanup at startup.
prynn13
Post by prynn13 » 21 Jun 2018, 17:18
any updates on this? Would love an scheduled scanning every X hour at selected path.
