tvOS testing 2.8.0 (161122.409)
Post by cosmoxl » 14 Nov 2016, 22:06
:D
videotoolbox is a rockstar with h264. seems steady at around 80% CPU no matter the bitrate.
Is it limited to only h264? Are there limitations as to the profile of h264? Interlaced material such as 1080i AVCHD from my video cam?
I have a test file that's remuxed from my Avarar blu-ray that for some reason is using software decode. Remux from other blu-rays done in the same manner are using VTB. I suppose you'll want to see a log?
mod edit
changes since 2.8.0 (161113.1842):
- better interlaced detection
- VTB :)
- fixed, tvOS. if we are paused when screensaver pops, come back paused unless we get pushed to background
- fixed, vtb on tvOS/iOS. if we pause and screensaver pops, vtb session becomes invalid and we need to reopen
- many other bug fixes and cosmetics
changes since 2.8.0 (161116.1752)
- fixed VTB playback
changes since 2.8.0 (161117.331)
- more VTB h264 fixes
Re: tvOS testing 2.8.0 (161113.1842)
Post by davilla » 14 Nov 2016, 22:27
Only h264, it can handle h264 high profile all the way up to 5.2 level and 4k size :) No h264 interlaced :(
There are rumors of h256 support but I've never found any details.
one dollar says your problem video is VC1. log will tell .
Post by cosmoxl » 14 Nov 2016, 23:30
davilla wrote:Only h264, it can handle h264 high profile all the way up to 5.2 level and 4k size :) No h264 interlaced :(
nope, Avatar isn't VC1. ff-h264 for some reason instead of VTB. I'll get the log to you when I get a chance. I've just got a new subwoofer so fooling with it. Previous one broke.
Post by cosmoxl » 15 Nov 2016, 01:45
log there of the blu-ray remux using ff-h264
I see the problem. For some reason it thinks it may be interlaced content. :?
Post by davilla » 15 Nov 2016, 02:01
NOTICE: Open - possible interlaced content.
Yep, it is interlaced :)
I use mediainfo
Scan type : MBAFF
Scan order : Top Field First
vs
Scan type : Progressive
Post by cosmoxl » 15 Nov 2016, 02:46
davilla wrote:NOTICE: Open - possible interlaced content.
I use mediainfo
Scan type : MBAFF
vs
no, it's not. :) it's a blu-ray remux. are there any interlaced blu-ray?
Here's mediainfo output:
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Format settings, GOP : M=3, N=24
Muxing mode : Header stripping
Codec ID : V_MPEG4/ISO/AVC
Duration : 1mn 2s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Default : Yes
Forced : No
Post by davilla » 15 Nov 2016, 03:16
very odd. any chance of a sample, say 1st 100-200MBs cut.
Post by cosmoxl » 15 Nov 2016, 03:22
davilla wrote:very odd. any chance of a sample, say 1st 100-200MBs cut.
yeah, that's what the test file is. how can I get it to you?
Post by davilla » 15 Nov 2016, 03:53
dropbox, google cloud, you know. the usual suspects :) you can email the url if you don't want it public.
Post by cosmoxl » 15 Nov 2016, 13:39
OK, I ask because sometimes developers have a site to which people can upload samples.
You'll be receiving an email from pcloud transfer at support at mrmc dot tv
Users browsing this forum: ersan191, Google [Bot], thomfam and 8 guests
