Please use this ONLY if you have downloaded 2.3.0 (160603.44), version number can be seen in TestFlight app
changes since 2.2.0 release version
+ picture memory hog killed and made into bacon
+ expand webserver blacklist check
+ missing dateadded sort method in AudioLibrary.GetSongs
+ subtitle manual search
+ long hold should bring playlist
+ disappearing SeekBar on chapter skip and ff/rew
+ ignore passthrough setting if iOS/tvOS audio is not routed to HDMI
+ iOS/tvOS channel mapping for transcode to ac3
+ iOS/tvOS channel mapping for iOS/tvOS for 7.1 pcm
+ keep renderer and friends from stalling
+ fix audio for wmapro
+ fixed, cpu percent used. zero out sleeping cpus
+ skin.amber, fix in progress overlay
+ fixed, smb_fstat on a directory
+ fixed, do not decode eia_608 subtitles
+ fixed, tvOS with audio set to Digital Dolby 5.1, it expects sink to use dd 5.1 channel mapping
tvOS Testing 2.3.0 (160603.44)
Re: tvOS Testing 2.3.0 (160603.44)
Installed the latest testflight.
I cleaned out my library yesterday and right now I have no movies with 7.1 audio...except a music blu-ray which has 96khz DTS-HD tracks.
The 7.1 track on that blu-ray is only outputting 5.1 PCM to my receiver. Could this be because MrMC is having to convert 96khz to 48khz? When I had movies 7.1 tracks (dolby true HD or DTS-HD) were outputting 7.1 PCM according to audio settings in MrMC.
Or is something else wrong? Is 96khz not possible through the ATV4?
Correct, 96khz not possible through the ATV4. It only supports 48khz.cosmoxl wrote:Installed the latest testflight.
What gets output is highly dependent on a) ATV4 audio settings and b) MrMC audio/speaker settings. Between these two, there are about 100+ possible combinations.
Just wanted to let you know that the two latest Testflights (including the one released today) broke DD 5.1 audio dowmix to 2.0 via HDMI in TVheadend. Only garbage coming out of the speakers. DD 2.0 is fine though.
- timstephens24
I just tested all the below audio mappings (for build 160604.1257) and don't have any issues:
DTS-HD MA (5.1) with Passthrough (played as DTS 5.1)
Left Speaker ---> Left Speaker
Center Speaker ---> Center Speaker
Right Speaker ---> Right Speaker
Right Surround ---> Right Surround
Left Surround ---> Left Surround
LFE ---> LFE
DTS-HD MA (5.1) w/o Passthrough (played as PCM 5.1)
LFE ---> LFE
Dolby TrueHD (7.1) w/ Passthrough (played as PCM 7.1)
Right Rear Surround ---> Right Rear Surround
Left Rear Surround ---> Left Rear Surround
LFE ---> LFE
Dolby TrueHD (7.1) w/o Passthrough (played as PCM 7.1)
LFE ---> LFE
DTS-HD MA (7.1) with Passthrough (played as DTS 5.1)
LFE ---> LFE
DTS-HD MA (7.1) w/o Passthrough (played as PCM 7.1)
Right Rear Speaker ---> Right Rear Surround
Left Rear Speaker ---> Left Rear Surround
LFE ---> LFE
Dolby AC3 (5.1) w/o Passthrough (played as PCM 5.1)
LFE ---> LFE
Dolby AC3 (5.1) w/ Passthrough (played as Dolby 5.1)
LFE ---> LFE
I also tested out the speaker phase with DTS-HD and didn't have any issues there either.
LFE ---> LFE
LFE ---> LFE
LFE ---> LFE
LFE ---> LFE
LFE ---> LFE
LFE ---> LFE
LFE ---> LFE
LFE ---> LFE
are you using some special test files for this? if so, are they free to download somewhere?timstephens24 wrote:I just tested all the below audio mappings (for build 160604.1257) and don't have any issues:
LFE ---> LFE
LFE ---> LFE
LFE ---> LFE
LFE ---> LFE
LFE ---> LFE
LFE ---> LFE
LFE ---> LFE
LFE ---> LFE
But... Please! Do not release this build to the AppStore. There are a lot of people who just connect their ATV directly to the TV. 2 of my 3 ATVs are connected like that.
have you posted your logs? might as well do it before they ask.HoIger wrote:Just wanted to let you know that the two latest Testflights (including the one released today) broke DD 5.1 audio dowmix to 2.0 via HDMI in TVheadend. Only garbage coming out of the speakers. DD 2.0 is fine though.
- timstephens24
I have a folder full of audio and video test files that I've collected over the years, including a Dolby AC3 speaker mapping test file, Dolby TrueHD 7.1 speaker mapping test file, a DTS-HD MA 7.1 speaker mapping test file, and a DTS-HD MA 5.1 speaker mapping test file. The great thing about these is that the video actually shows the speaker that is outputting the audio, so you can easily tell if they're mapped properly. I'm honestly not sure if they're free to download (but I assume they are since they're test files and not a movie), so just google for them and you'll find them out there.cosmoxl wrote:are you using some special test files for this? if so, are they free to download somewhere?
I also have others, like Atmos, 3D, 3D with subtitles, 4K, 10 bit processing, etc etc etc. I've made a few myself to test for black levels and other things for TV Shows/Movies that I've found had black level issues so I can test if settings on a TV are good or not. I'd highly recommend finding things that you can use to test different things that you might have issues with depending on what you might find important. It also helps if you use a few different Media Centers like I do too.
DD and DTS websites have test files for downloading.
