Please use this ONLY if you have downloaded 2.2.0 (160515.2041), version number can be seen in TestFlight app
changes since 2.1.0 release version
+ fixed channel mapping
+ added native ac3/eac3 decoder
+ bring back .divx file playback
+ cosmetic skin fixes
+ libdsm 0.2.2
+ fixed frame dropping
+ changed, libdsm. always translate hostname to ip for libdsm
+ setting to treat 'menu' button as escape in full screen playback
+ fixed, picture sucking memory pig
+ fixed, missing dateadded sort method
+ pvr epg search
+ fixed manual search string in subtitle download
tvOS Testing 2.2.0 (160515.2041)
Re: tvOS Testing 2.2.0 (160515.2041)
Hello,
Thank you for the new build. I have an isse since the last testflight builds. If you long press the enter button on a live tv channel, you get a quick channel menu. But since the last testflight builds i just get a video info screen with:
D(ac3)
D(h264)
Cpuinfos
Could you please bring back the channel switch menu?
Thank you!
D(ac3)
D(h264)
Cpuinfos
Thank you!
2.1.0 is fine?
This is in full sceeen video playback, correct?
Yes it's in full screen video playback. Version 2.1 in the app store is fine.
I'll check, thanks!
I've been having a bit of an issue with the screen calibration over the past few versions (started quite a while back, just gotten around to reporting it, sorry).
Basically, I calibrate the screen size correctly and go on my way. Eventually (not too sure what causes it, I usually leave MrMC open and the ATV on, no sleep) I'll notice that MrMC has pushed itself out past the borders of the screen, so some stuff is cut off around every border. If I then calibrate the screen again to fix it, eventually (a couple of days later maybe) I'll notice that it's "fixed" itself, but in doing that it's gone too far the other way, in that MrMC is now too small (by however much I needed to adjust it by to "fix" it the first time I assume).
One perculiarity is that although the screen is now too small (so there are black borders around each edge), the main menu text items seem to behave correctly and extend out to the correct widths of the screen.
Not sure if you can tell from this crappy picture, but my TV has a super thin bezel so where it looks black, that's actual screen:
I haven't found a way around this, and as I said its persisted over a few versions now. Not sure what I can provide to help with this one?
seen it before on old Kodi MacMini, happens when switching between different inputs on my audio amplifier.
there was a setting on my TV that fixed it, something to do with overscan or something ... can check later, but look around on your TV.
we have not changed anything there and there is nothing for us to change anyway. We feed AppleTV 1920x1080 picture and appleTV deals with different resolutions according to its settings and what TV can take.
Sometime during the past several betas my 5.1 and DTS passthrough became inconsistent, often playing in Stereo. Some videos work fine. Audio setting default is set for enable passthrough. Stereo up mix is off. audio stream indicates English 5.1 or DTS but it's grayed outl
make sure sync to display is disabled if you want passthrough
found it, fixed it... will be back in next TFd00dl3 wrote:Yes it's in full screen video playback. Version 2.1 in the app store is fine.
