Testing MrMC 3.8.0 - [Invites Closed]
Post by davilla » 13 Jan 2019, 17:44
Released for tvOS.
ec3/atmos for tvOS.
dropbox is back, see webserver to authorize.
3.8.0 (190126.1441)
refactor ec3/atmos (tvOS)
upate webserver ui
emby: fix manual sigh-in on 4.* servers
3.8.0 (190127.1447)
restore passthrough if <= tvOS 11.2
fixup webserver
3.8.0 (190203.1722)
core: iOS/tvOS, check color_primaries when deciding SDR/HDR/DolbyVision
core: iOS/tvOS, fix audio sink channel setup when max channels == 2
core: remember last server selected on home
core: add video demuxer color primaries to hints
core: ffmpeg/atmos, only trust eac3/atmos if framesize is 1792
core: fixup, atmos: ec3/atmos for iOS/tvOS
ios/tvos: new icons
android: new icons
plex: clear server type and server UUID on sign-out
emby: ignore folders from emby, they show on home screen
3.8.0 (190208.208)
core: no input if splash is up
skin: sync opacity/ariana
3.8.0 (190209.2032)
core: add video splash detection, disable res switching if running
core: run splash video from application, not from the skin
FIX: AC3 is not always 32ms
ADD: [amc;debug] log supported mime types
CHG: [droid] come back to mrmc after a youtube play
FIX: [droid] force https for youtube channel trailers
CHG: [droid] audio refactor
FIXUP: ActiveAE: Differentiate DTS-HD-MA and DTS-HD-HR
FIXUP: [cmake] add DolbyFrameParser & MemoryBitstream
emby: fix external subtitles
FIX: folders on home
3.8.0 (190210.1834)
core: try harder when m_sink->AddPackets return zero
core: iOS/tvOS, temp disable CDVDAudioCodecAudioConverter for AC3
plex/emby: home server selection fix
Revert "load home buttons once only, no point doing it over and over again"
CHG: [amc] warn if we are over-buffering demux packets
FIX: [amc] no bitstream + demux queuing -> havoc
FIXUP: pass channel config to settings audio visibility check
FIXUP: DTSHD / DTSHD_MA split
FIXUP: [droid] Remove "AMC + SD" setting; we now have a detailed one
fixme: core: add video splash detection, disable res switching if running
3.8.0 (190211.228)
core: iOS/tvOS, temp disable CDVDAudioCodecAudioConverter for EAC3
3.8.0 (190216.1918)
kill video splash for now
core: tvOS, move video splash into app delegate.
tvos: cleanup unused settings
add logging to CGUIWindowHome
AE: fix sync for transcoding
make ariana default skin on all devices
android: add android.touch.xml to select ariana touch as default skin on touch devices
CHG: re-add the "splash" AS for those preferring a plain splash image
FIXUP: [at] IEC HD
if mime type is video/ item cant be Audio
splash: do not hit database when video splash is playing
cleanup: remove skin checks for opacity, ariana and sio
video splash with sound
fixme: set light/dark theme from core
ios: UIInterfaceOrientationMaskLandscapeRight if device has notch
add: CDarwinUtils::IosHasNotch
fixme: ocd: UI flash before static splash :)
Revert "plex/amby: check if service is running when checking for clients"
fixme: remove : CSettings::SETTING_VIDEOLIBRARY_HOMESHELFITEMS
fixme: fully remove totals from HomeJob
rework recently added Announcement handling
show splash before anything else
3.8.0 (190217.2127)
plex: enable parallel transcoded thumb fetching
emby: more emby love
emby: home screen fixes
fix: startup crash when initialize databases
tvos: disable video splash for now
FIX: [amc] base frame scheduling on frame duration rather than fps
CHG: Actually use hint.dvd
ADD: [droid] ability to force MPEG2 on DVD to h/w
REVERT: [droid] PT stereo is fine again
FIX: [AT] fix RAW HD
FIX: [AE] error handling
Re: Testing MrMC 3.8.0 - [Invites Closed]
Post by cosmoxl » 13 Jan 2019, 18:10
AMC for mpeg2 on Shield? :)
barong
Post by barong » 13 Jan 2019, 22:26
Do you require any logs for the current Emby server beta connection issues?
Post by davilla » 13 Jan 2019, 22:44
barong wrote:
13 Jan 2019, 22:26
not yet, thx.
Post by timstephens24 » 14 Jan 2019, 22:00
No issues so far, and the two files I have with EAC-3 plus Atmos plays back as Atmos.
##### SYNOLOGY 1815+ #####
barong
Post by barong » 14 Jan 2019, 23:43
New icon looks slick :)
Post by timstephens24 » 15 Jan 2019, 02:18
barong wrote:
14 Jan 2019, 23:43
I'm not a huge fan but it's an icon so w/e lol
Everbrave
Post by Everbrave » 15 Jan 2019, 09:13
timstephens24 wrote:
15 Jan 2019, 02:18
barong wrote:
14 Jan 2019, 23:43
Anyway, the website still carries the old icon!
Everbrave
Post by Everbrave » 15 Jan 2019, 09:15
14 Jan 2019, 22:00
With or without passthrough enabled?
Post by timstephens24 » 15 Jan 2019, 10:33
Everbrave wrote:
15 Jan 2019, 09:15
14 Jan 2019, 22:00
Without
