tvOS 11.4 Opacity:
Is the wiggle still work in progress for channel list with PVR in Opacity ?
Otherwise I would like to option to disable it, for fast swipes through channel list, where wiggle animation just looks like something is wrong with gui animation, between swipes.
- timstephens24
Re: Testing MrMC 3.7.0
Just noticed this, but Ariana doesn't have a search that I could find like Opacity does. It's rare that I use search, but I like it instead of scrolling when I know exactly what I'm looking for.
Also, is there going to be another iOS build? I'd like to see if any of the issues brought up there have been addressed.
- wrxtasy
- pecinko
timstephens24 wrote: ↑24 Jun 2018, 23:38 Also, is there going to be another iOS build? I'd like to see if any of the issues brought up there have been addressed.
- Everbrave
That is a game changer for the iOS app!pecinko wrote: ↑25 Jun 2018, 10:02timstephens24 wrote: ↑24 Jun 2018, 23:38 Also, is there going to be another iOS build? I'd like to see if any of the issues brought up there have been addressed.
Great Job
Does no one else see this? It's a real critical bug for me on the shield.tredman wrote:Been meaning to report this for ages, but not had time. For a good while I have had issues with live tv on the test flights, stuttering and dropped images and sound - its completely unwatchable. I'm watching UK DVB-S2 HD content from tvheadend - works fine in SPMC & Android Kodi.
Log is here:
https://pastebin.com/qivT7xc2
I have exactly the same issue on all my shields (mix of 4k, 1080p and 720p outputs).
If you I can help with more info please let me know.
Edit - note although this log is from one of my sheild running on Oreo I see *exactly* the same issue on the 2 shields which are not upgraded to 8
