I have this problem occasionally in 11.3 beta. I reboot(restart) the ATV4k and then it works again.
Testing MrMC 3.5.1
Re: Testing MrMC 3.5.1
Testing MrMC 3.5.1
I’m gonna give a try right now ...cosmoxl wrote:I have this problem occasionally in 11.3 beta. I reboot(restart) the ATV4k and then it works again.
LePousson
EDIT : Yes, a reboot of the ATV4K fixed the problem. But why was it working well with 3.5.0, even under 11.3 Beta ?´
yeah, I see it too.. will look into it.. thanks!Ted377 wrote: ↑21 Mar 2018, 00:45Normal TV via TVHeadend. Otherwise, the stations can be zapped through, only after the last update is it no longer possible. In addition, you could have the station list by long press the OK button.davilla wrote: ↑20 Mar 2018, 21:47More specific please, normal TV Shows, using pvr ? using plex/emby clients or plex for kodi.Ted377 wrote: ↑20 Mar 2018, 21:42 Okay, this update has gotten worse for me.
1. if I want to watch TV and switch, then the program is only forward or rewound.
2. otherwise the channel list would be displayed when the OK button is pressed, now the current TV program is paused. I think that's not what it's meant to be.
Will go back 2 versions and on the upcoming Updatewartem
- Ted377
Alrightamet wrote: ↑21 Mar 2018, 06:21yeah, I see it too.. will look into it.. thanks!
Is any of these things possible to solve?SUPERBIF wrote: ↑20 Mar 2018, 11:59I don't know if it makes sense to look at how PlexKodiConnect does it on normal Kodi, there it works perfect also saving in same folder, but perhaps it's a completely different structure, I don't know.amet wrote: ↑18 Mar 2018, 07:55its a bit difficult, all direct play files are called file.mkv so we would need to come up with a different way of matching the names... I will look into is at some point after all the python mess is doneSUPERBIF wrote: ↑18 Mar 2018, 06:55 ...
I've also asked for this earlier. It would be excellent if you could save the subtitle with the correct name and in the same folder ad the video. Hopefully now the Direct Plex is available it perhaps can be possible. It works in Kodi when you use PlexKodiConnect (Plex addon). It would make things much easier.
Some feedback on Plex for Kodi. It's very nice work.
What I had problems with are the following:
- When Download subtitle screen automatically appear when no current subtitle, you can't navigate in that window.
- Would it somehow be possible to use the same buttons as in MrMC. Have siricustomcontroller.xml configured, but these functions doesn't work in Plex for Kodi. And when playing videos, I had mapped buttons for subtitledelay, subtitledownload etc. but not working anymore.
- Would it either be possible to create custom buttons for switching profile, so it exits Plex for Kodi and goes directly into TV section and visa versa?
- Would it be possible to have own movie rating like in standard Plex/MrMC?
- Can you predefine somehow which audio language video should be as standard like in normal MrMC?
- Is there a wait for network connection timeout before entering Plex for Kodi already?
Thanks for the great work you guys are doing.
Nothing changed in MrMC regarding display switching from 3.5.0 to the current 3.5.1 in TestFlight. I did read that beta 6 did screw up display switching.LePousson wrote: ↑21 Mar 2018, 04:02I’m gonna give a try right now ...cosmoxl wrote:I have this problem occasionally in 11.3 beta. I reboot(restart) the ATV4k and then it works again.
LePousson
1 - might be a regression, will look into it.SUPERBIF wrote: ↑21 Mar 2018, 08:10 1 - When Download subtitle screen automatically appear when no current subtitle, you can't navigate in that window.
2 - Would it somehow be possible to use the same buttons as in MrMC. Have siricustomcontroller.xml configured, but these functions doesn't work in Plex for Kodi. And when playing videos, I had mapped buttons for subtitledelay, subtitledownload etc. but not working anymore.
3 - Would it either be possible to create custom buttons for switching profile, so it exits Plex for Kodi and goes directly into TV section and visa versa?
4 - Would it be possible to have own movie rating like in standard Plex/MrMC?
5 - Can you predefine somehow which audio language video should be as standard like in normal MrMC?
6 - Is there a wait for network connection timeout before entering Plex for Kodi already?
2 - possible, we have to see how plex for kodi handles buttons and keymaps.
3 - see 2
4 - maybe in the future, we are trying to minimize changes to plex for kodi until we understand it better.
5 - see 4
6 - I tend to dislike hanging for network connections. Creates too many paths to deal with. Pretty sure it has a network timeout already, so I make it longer and the connection is still not there ? Now what ?
Please make requests in the requests section. TestFlight thread is for testing and fixing issues. If requests are made here, they can get lost where as we review the requests postings.
To those experiencing hangs on auto start of plex for kodi. What else is enabled ? PVR, internal plex/emby clients ? WOL ? Scan lib on startup ? Anything that might get invoked on startup. Also include which skin you are running.
I've tried under both AppleTV 4 and AppleTV 4K, and I just can't get it to hang.
Skins: It hangs in Opacity skin at main menu AddOns or Plex. I tried MrMc skin and it hung at main menu Music. I couldn’t figure out how to execute the Plex add on in Black Glass. Interesting, when I changed Appearence setting from Black Glass back to Opacity, said yes to the change, it brought me right into the Plex Addon Plex Home screen. So that maneuver bypassed whatever is making it hang.
Setting services Plex client shows I have Plex library RT update interval set at 10 mins. Home shelf is Local server only. No emby or other Services. Settings/video/library does have Update library on startup checked. I tried unchecking that and it hangs at main menu Addons. Hide progress of library updates is unchecked. I don’t have profiles. Is there somewhere else that has update Plex library at startup? Here’s a new log. Arghh.
https://pastebin.com/T6YCKk7b
Let me know what else I can try.
lets outline the steps you do to make it hang. MrMC is not running (vs in background), you click on MrMC, it starts up, does splash, then goes to auto-start plex for kodi.
What you see is plex hilighted in addons window ? yes.
Waiting a long time 30-60 seconds, it's still there. But you can do a select and plex for kodi then runs ?
Trying to make sure we are on same page as I'm not looking over your shoulder
