Testing MrMC 3.4.1
Moviejunkie
Re: Testing MrMC 3.4.1
Post by Moviejunkie » 13 Jan 2018, 11:10
Much better remote control now! Great.
One question: How can I scroll the content movie text by Blakck Glas Skin?
Post by amet » 13 Jan 2018, 11:41
Moviejunkie wrote:
13 Jan 2018, 11:10
... One question: How can I scroll the content movie text by Blakck Glas Skin?
could you explain more please, or post a photo of it
Ted377
Post by Ted377 » 13 Jan 2018, 12:28
As soon as messages such as "Tvheadend HTSP Client Tuning failed" appear, the remote control stops responding. This lasts until the message is hidden again. Is that known?
https://pastebin.com/Z065GuPv
Montoya
Post by Montoya » 13 Jan 2018, 12:49
I also notice a locked state of the Siri remote, while the DVBLink PVR is updating its guide, when MrMC is just started.
Before, I could navigate in the interface while the guide was updating.
Edit: I'm using the Opacity skin
Moviejunkie
Post by Moviejunkie » 13 Jan 2018, 13:46
@amet:
https://www.dropbox.com/s/fwt3jblbxb5uz ... 8.jpg?dl=0
I want to see the full movie description
Second, one small fault with the new beta:
My TV doesn't switch to HDR anymore with all HDR files.
Cinema movies are working but test files not:
https://www.dropbox.com/s/pqsd08g278ogv ... 10.ts?dl=0
This is the file
Post by amet » 13 Jan 2018, 14:02
Moviejunkie wrote:
13 Jan 2018, 13:46
@amet:
Settings > Appearance > Skin > - Settings > General Settings > Enable auto scrolling .. but these reports should not go into TestFlight thread please, we are looking for issues with currently testing features/bugfixes
Moviejunkie wrote:
13 Jan 2018, 13:46
This is the file
does 3.4.0 work ok for you?
Itzme1234
Post by Itzme1234 » 13 Jan 2018, 14:15
With native tvOS Native sounds on, in Opacity Movies/Titles the down swipe will make a sound but the 2nd and subsequent down swipes won't make any sound. Same seems true with Up. Left and right seem fine. This happens when scrolling any wall with the Siri remote.
This issue doesn't happen when I use my 3rd party remote, only on the Siri.
Post by cosmoxl » 13 Jan 2018, 16:44
13 Jan 2018, 08:59
3.4.1 (180113.440)
- more Siri remote fixes
- fake uisounds addon to allow for tvOS native sounds
Is there supposed to be anything different with the sounds compared to previous build? I guess this is just your way of making sure both MrMC and tvOS sounds aren't at the same time?
BTW, last night I had a crash out of the app that was unassociated with any button press. The cursor was in the in progress section of TV Shows and I think it was doing a background library update....and boom. Sorry, I didn't get a log.
Post by amet » 13 Jan 2018, 17:09
cosmoxl wrote:
13 Jan 2018, 16:44
yeah, just a selector so users can choose the one they like
Post by davilla » 13 Jan 2018, 17:22
3.4.1 (180113.440) has subtile underlying focus handling changes and exposes a setting to control tvOS nav sounds (enable/disable) as well as normal gui sounds. The idea is you can have none, gui or tvos.
