I know Cosmoxl, that's why I said:
And also, why not have best of BOTH worlds, with tapping functionality together with scrubbing thumbnail for big controlled jumps and the precise scrubbing navigation in content with the touchpad.
Perhaps this is important to the situation at hand, perhaps not, but I also noticed when playing those home videos with deinterlace selected that audio sync got progressively worse, such that after just a bit it was several seconds off. Maybe that's affecting proper thumbnail creation? With bob-inverse sync was good.davilla wrote: ↑18 Jan 2018, 20:39
"have some problem showing the proper thumbnail when deinterlace is selected, but the problem pretty much clears up when bob-inverted is used" Actually, that would be no deinterlacing as bob-invert is a renderer/gpu deinterlacer. Sounds like I can just turn off deinterlacing.
"scrubbing but get no thumbnail at all which also means I don't see a timestamp" : Something we are thinking about. Ideally if there is no image, the timestamp should get shown.
just ATSC broadcast TV, 720p and 1080i, from Plex, not dvblink add-on. Plex has DVR capabilities now, so I figure this is something important to nail down if possible. Don't laugh about that second one I didn't have any 1080i already recorded so I recorded the first 1080i show for a minute that I came across.
This is working fine, except one thing... It seems like when you click the progress bar doesn't go all the way to where you selected, so visually it looks like it's starting earlier, but it's not.davilla wrote: ↑18 Jan 2018, 17:39 If "Enable Sire expert mode" is disabled, and scrubbing is possible, then on a select, playback will pause and the player progress bar pops up. You can go left or right to move the seek point and a thumbnail image will be shown along with timecode. Select to start playback at that point. Menu is a cancel and playback continues from where it was paused.
So a lot of issues for me. Side clicking to jump doesn't work and I end up back at the beginning of the movie/tv show (00:00:00). That's what I'd call "not good" since it's completely not consistent with the Apple TV remote anywhere else.
native players will take a click on the side of the siri remote to be 10seconds back or 10 seconds forward, depending on which edge of the remote your thumb is on, left or right. usually you can even do multiple clicks so that it adds up 10+10+10 and so on. It isn't necessary to stop playback to do this.davilla wrote: ↑18 Jan 2018, 22:37 The native tvOS player does not respond to left/right taps in the progress bar. Only pans/swipes. Any App that responds to taps has added that ability.
Just how are you 'side clicking" ? with Sire remote or Harmony remote ? Also what content and where is it located ? local or remote ?
Anything in iTunes, Netflix, Vudu, Amazon, etc etc etc etc (basically all the apps) do side clicking for 10 second jump forward and 10 second jump back. If you touch on the side it even pops up the progress bar and shows you're about to a 10 sec jump (with a nice icon even). If you tap to bring up UI and then tap again it even changes how long is left (i.e. -40 min) to the exact time it'll end (i.e. 9:57 pm). Even other apps like Channels with their own UI/Player do the same side clicking (but they do 30 seconds forward and 10 second back customizable).davilla wrote: ↑18 Jan 2018, 22:37 The native tvOS player does not respond to left/right taps in the progress bar. Only pans/swipes. Any App that responds to taps has added that ability.
