Testing MrMC 3.4.1
- Everbrave
Re: Testing MrMC 3.4.1
I want to support the other calls for "Swipe-down for Subtitles and Audio selection"; the current implementation is really very "touchy"; literary
How do you get Harmony to pair with Apple TV4k with bluetooth. I can only get it to work in IR.three6zerocool wrote: ↑19 Jan 2018, 08:47 Ok, installed latest testflight build.
Discovered slight issue right away.... Cursor control is busted for 3rd party remotes.
I use a Harmony Elite remote via Bluetooth.
With latest build, can not skip forward or back using left and right arrow keys. larger increment skipping using up and down arrow keys is dead too.
Reinstalled previous build 3.41 (180113.2009) and cursor keys on my Harmony remote work again.
I think he means "Harmony Elite remote --> to HUB with BT --> HUB to ATV4K with IR "SUPERBIF wrote: ↑19 Jan 2018, 22:04How do you get Harmony to pair with Apple TV4k with bluetooth. I can only get it to work in IR.three6zerocool wrote: ↑19 Jan 2018, 08:47 Ok, installed latest testflight build.
I have that combo and Apple doesn't allow Hub to pair with AppleTV's
What did you see? Since yadif isn't keeping cadence like it should I tested bob-inverse on a 1080i recording and saw high contrast areas with the same problem I used to see a year ago or so - As if it's not really being deinterlaced. A stop sign panning across the screen looks like the white lettering and red background jump at different times and there are artifacts at the edge of the sign too. I hadn't seen such problems in a while.
try deinterlace/half
everything looks oddly slow motion or as if it's dropping/skipping frames. But, codec info says it's not.
codec info sometimes lies
because we can't handle the truth?
Think I found it, was sucking away CPU ponies updating the layers when playing video.
good news! I look forward to testing.
I'm used to seeing it named yadif and yadif(2x). I assume deinterlace-half = yadif and is supposed to create 1 frame from 2 fields, while deinterlace = yadif(2x) and makes a frame out of each field?
